[GRASS-dev] Metadata GRASS (GSOC)
Matej Krejci
matejkrejci at gmail.com
Sat May 17 00:19:41 PDT 2014
> I was wondering was whether it would be possible to extract from pycsw
> just the part for reading/writing the xml meta-data, without all the
> overhead linked to its status as a server.
> More generally, I just think that we can't be the only ones working on
> metadata in a Python environment and that we maybe not have to reinvent the
> wheel.
I got news that OWSLib can be used for parse XML according ISO without
dependence on pycsw server. In addition I found that there is a pycsw
package in UbuntuGIS and also there is a plan to develop package for Debian
with the development should start probably after couple of months. OWSLib
have dependence only on lxml so this is not a barrier. If we use OWSLib for
first task, it could to ensure a smoother continuity to develop second
task- pywps.
Matej
------------- dal�� ��st ---------------
HTML p��loha byla odstran�na...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140517/57d46c47/attachment.html>
