[GRASS-dev] [GRASS GIS] #1628: segfault in r.walk
Glynn Clements
glynn at gclements.plus.com
Sat May 17 10:33:09 PDT 2014
GRASS GIS wrote:
> I have removed the lib/sites dependency of v.vol.rst in 7.x in r60272
> (trunk) and r60273 (relbr7).
That appears to leave v.in.sites as the only client of lib/sites. And
it only uses the "oldsite" functionality (i.e. reading GRASS 5.x
"sites" maps), as opposed to using the legacy sites API to access
vector maps):
grass=> SELECT i.symbol, i.object
grass-> FROM obj_exp e, obj_imp i
grass-> WHERE e.object LIKE 'lib/sites/%' AND e.symbol = i.symbol ;
symbol | object
G_site_new_struct | vector/v.in.sites/OBJ.x86_64-unknown-linux-gnu/main.o
G_site_free_struct | vector/v.in.sites/OBJ.x86_64-unknown-linux-gnu/main.o
G_oldsite_describe | vector/v.in.sites/OBJ.x86_64-unknown-linux-gnu/main.o
G_oldsite_get | vector/v.in.sites/OBJ.x86_64-unknown-linux-gnu/main.o
G_oldsites_open_old | vector/v.in.sites/OBJ.x86_64-unknown-linux-gnu/main.o
(5 rows)
Is there any reason to retain lib/sites as a separate library, rather
than simply merging it into v.in.sites? There isn't a ctypes wrapper
for it, so I'm reasonably sure it isn't used elsewhere in GRASS.
[Radim: does QGIS use it?]
