[GRASS-dev] wxGUI customized toolboxes: handler for non-GRASS commands
Yann Chemin ychemin at gmail.com
Sat May 17 20:46:53 PDT 2014
Hi Anna,
Patch works great ! Needs RunMenuCmd and all goes to perfection. Any
chance to have it included in the SVN tree?
Thank you
Yann
On 18/05/2014, Anna Petrášová <kratochanna at gmail.com> wrote:
> Hi Yann,
> it's grayed out because it tests if it's a working grass command (for
> example r.in.lidar is grayed when you don't compile grass with liblas). You
> can try to apply this patch which tests if the command looks like grass
> command (regular expression) and if it is not, it doesn't disable it in
> menu.
> Index: gui_core/menu.py
> --- gui_core/menu.py (revision 60284)
> +++ gui_core/menu.py (working copy)
> @@ -18,7 +18,7 @@
>  @author Robert Szczepanek (menu customization)
>  @author Vaclav Petras <wenzeslaus gmail.com> (menu customization)
> +import re
>  import wx
>  from core              import globalvar
> @@ -91,7 +91,8 @@
>                  cmd = utils.split(str(command))
>              except UnicodeError:
>                  cmd = utils.split(EncodeString((command)))
> -            if cmd and cmd[0] not in globalvar.grassCmd:
> +            if cmd and cmd[0] not in globalvar.grassCmd and \
> +               re.match('[rvdipmgt][3bs]?\.([a-z0-9\.])+', cmd[0]):
>                  menuItem.Enable(False)
>          rhandler = eval('self.parent.' + handler)
> On Fri, May 16, 2014 at 12:30 AM, Yann Chemin <ychemin at gmail.com> wrote:
>> in svn/gui/wxpython/lmgr/frame.py
>> line 758
>> by adding:
>>     def RunCmd(self, event = None, cmd = []):
>>         """!Run command to system from menu"""
>>         if event:
>>             cmd = self.GetMenuCmd(event)
>>         os.system(cmd)
> I am not sure if this is needed. I would say it might work without this
> change but you have to try it out.
> Best,
> Anna
>> it should handle it, however, it seems that a flag is needed to enable
>> the possibility to click the command from the created menu. It is
>> still grey/shadowed.
>> On 16/05/2014, Yann Chemin <ychemin at gmail.com> wrote:
>> > To be precise, the non-GRASS programs have their own GUI already, and
>> > the calls need only one word.
>> >> Hi,
>> >> I would like to make a customized toolbox to call some non-GRASS CLI
>> >> programs.
>> >> Handlers OnMenuCmd and RunMenuCmd seem not to work. The menu items are
>> >> grey/shadowed so that no mouse click is allowed on them.
>> >> thanks
>> >> Yann
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
