[GRASS-dev] [GRASS-SVN] r60309 - grass/trunk/vector/v.clean
Huidae Cho grass4u at gmail.com
Sun May 18 02:50:13 PDT 2014
Yes, I'm doing it. I need time to login & type. ;-)
On Sun, May 18, 2014 at 5:46 AM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2014-05-18 11:41 GMT+02:00  <svn_grass at osgeo.org>:
> > Author: hcho
> > Date: 2014-05-18 02:41:14 -0700 (Sun, 18 May 2014)
> > New Revision: 60309
> > Modified:
> >    grass/trunk/vector/v.clean/main.c
> > Log:
> > v.clean: Option thresh => threshold
> for record -- if you change option name that you should also note that
> at dedicated trac page [1].
> Thanks, Martin
> [1] http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Optionschanges
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140518/8f567e42/attachment.html>
