[GRASS-dev] r.stream.* to trunk - what about r.stream.basins?
Martin Landa
landa.martin at gmail.com
Sun May 18 06:34:14 PDT 2014
Hi Markus,
2014-04-06 15:52 GMT+02:00 Markus Metz <markus.metz.giswork at gmail.com>:
> Now the modules are even in a release branch. If have disabled them in
> releasebranch_7_0 because the results of the all-in-RAM and the
> external-memory mode are not identical. Further, the code needs
> cleaning up. IMHO, the modules should also be disabled in trunk,
> cleaned up, tested, then activated again and backported to
> releasebranch_7_0.
do you agree to remove r.stream.* modules (with one exception
r.stream.extract) from release branch 70?
Martin
