[GRASS-dev] wxGUI customized toolboxes: handler for non-GRASS commands
Yann Chemin ychemin at gmail.com
Sun May 18 07:03:52 PDT 2014
Hi Anna,
Thank you, updating trunk now !
About RunMenuCmd, it is just a note to remember that it is the call to
use for external program. All good there.
Yann
On 18/05/2014, Anna Petrášová <kratochanna at gmail.com> wrote:
> Hi Yann,
> On Sat, May 17, 2014 at 11:46 PM, Yann Chemin <ychemin at gmail.com> wrote:
>> Hi Anna,
>> Patch works great ! Needs RunMenuCmd and all goes to perfection. Any
>> chance to have it included in the SVN tree?
> I committed the patch in trunk, if you agree, I won't backport it now. I
> don't understand what do you mean with RunMenuCmd, is there still some
> problem and what is it exactly?
> Anna
> Thank you
>> Yann
>> > Hi Yann,
>> > it's grayed out because it tests if it's a working grass command (for
>> > example r.in.lidar is grayed when you don't compile grass with liblas).
>> You
>> > can try to apply this patch which tests if the command looks like grass
>> > command (regular expression) and if it is not, it doesn't disable it in
>> > menu.
>> > Index: gui_core/menu.py
>> > --- gui_core/menu.py (revision 60284)
>> > +++ gui_core/menu.py (working copy)
>> > @@ -18,7 +18,7 @@
>> >  @author Robert Szczepanek (menu customization)
>> >  @author Vaclav Petras <wenzeslaus gmail.com> (menu customization)
>> > +import re
>> >  import wx
>> >  from core              import globalvar
>> > @@ -91,7 +91,8 @@
>> >                  cmd = utils.split(str(command))
>> >              except UnicodeError:
>> >                  cmd = utils.split(EncodeString((command)))
>> > -            if cmd and cmd[0] not in globalvar.grassCmd:
>> > +            if cmd and cmd[0] not in globalvar.grassCmd and \
>> > +               re.match('[rvdipmgt][3bs]?\.([a-z0-9\.])+', cmd[0]):
>> >                  menuItem.Enable(False)
>> >          rhandler = eval('self.parent.' + handler)
>> > On Fri, May 16, 2014 at 12:30 AM, Yann Chemin <ychemin at gmail.com>
>> > wrote:
>> >> in svn/gui/wxpython/lmgr/frame.py
>> >> line 758
>> >> by adding:
>> >>     def RunCmd(self, event = None, cmd = []):
>> >>         """!Run command to system from menu"""
>> >>         if event:
>> >>             cmd = self.GetMenuCmd(event)
>> >>         os.system(cmd)
>> > I am not sure if this is needed. I would say it might work without this
>> > change but you have to try it out.
>> > Best,
>> > Anna
>> >> it should handle it, however, it seems that a flag is needed to enable
>> >> the possibility to click the command from the created menu. It is
>> >> still grey/shadowed.
>> >> On 16/05/2014, Yann Chemin <ychemin at gmail.com> wrote:
>> >> > To be precise, the non-GRASS programs have their own GUI already,
>> >> > and
>> >> > the calls need only one word.
>> >> >> Hi,
>> >> >> I would like to make a customized toolbox to call some non-GRASS
>> >> >> CLI
>> >> >> programs.
>> >> >> Handlers OnMenuCmd and RunMenuCmd seem not to work. The menu items
>> are
>> >> >> grey/shadowed so that no mouse click is allowed on them.
>> >> >> thanks
>> >> >> Yann
>> >> _______________________________________________
>> >> grass-dev mailing list
>> >> grass-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
