[GRASS-dev] [GRASS GIS] #2120: wxgui: encoding errors
trac at osgeo.org
Sun May 18 13:02:21 PDT 2014
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: wxGUI | Version: svn-releasebranch64
Keywords: locale encoding | Platform: Unspecified
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:7 hcho]:
> I'm not sure if it's a good idea to include this file in GRASS SVN
It isn't.
It's working around a bug, namely that Python's default encoding is being
used. Fix the bug, not the symptoms.
> I don't know why the encoding setting in Preferences doesn't work. It
seems like we cannot change the default encoding outside sitecustomize.py.
That's correct. The reason is related to the use of hashtables to
implement dictionaries (including those which underlie Python objects).
When a Unicode object is hashed, if it can be converted to a byte string
using the default encoding then it is, and the resulting string's hash is
used. This allows a dictionary key which is a string to be matched using
the string's Unicode equivalent, and vice-versa.
However, if the default encoding is changed after any non-ASCII keys have
been added to dictionaries, any lookups for those keys would use the wrong
hash and fail. To protect against this possibility, the site module
deletes the setdefaultencoding() function from the sys module after
loading the sitecustomize and/or usercustomize modules. Basically, once
the interpreter is fully "up and running", the default encoding is fixed.
Note that Python's default encoding (as per sys.getdefaultencoding()) is
only used for implicit conversions between str and unicode objects, e.g.
via the str() and unicode() constructors, or via the C API (e.g.
`PyString_AsString`). But not for filenames (see below).
It is not the same thing as the locale's default encoding as per
locale.getpreferredencoding() or locale.getdefaultlocale(). Nor is it the
same thing as the filesystem encoding as per sys.getfilesystemencoding(),
which is used for converting filenames (from unicode to str on Unix, Mac
and Windows 9x, from str to Unicode on Windows NT). These are what
application code should be using.
So, the implicit conversions should never be used by wxGUI. Conversions
between Unicode strings (which is what wxPython normally uses) and byte
strings should be explicit, with a specified encoding (e.g. that from the
locale, unless information is available to indicate a different encoding).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2120#comment:10>
