[GRASS-dev] r.stream.* to trunk - what about r.stream.basins?
Sun May 18 13:12:02 PDT 2014
Markus Metz wrote:
> IMHO, the modules should also be disabled in trunk,
I'm not a fan of having disabled code in trunk.
Code which isn't being compiled will be overlooked when API changes
(or build system changes, etc) are made, and will start to suffer from
bit-rot.
If compilation generates errors, that serves as a reminder to do
something about it.
If you're worried about people trusting a module's output, add a
G_warning().
