[GRASS-dev] r.in.lidar tuning
Hamish
hamish.webmail at gmail.com
Sun May 18 21:30:08 PDT 2014
> [ wish for r.in.lidar: ]
> >>> filter Only import points of selected return type
> >>> If not specified, all points are imported
> >>> options: first,last,mid
> >>> which would be great for r.in.lidar as well to avoid that I need
> >>> to split the file with las2las beforehand.
Markus Neteler wrote:
> I have implemented that now in
> http://trac.osgeo.org/grass/changeset/60247/grass/trunk/raster/r.in.lidar
> (hope I got it right over from v.in.lidar)
you might look at the vrange= "Filter range for alternate value column data (min,max)" was implemented for r.in.xyz, I humbly think the approach there is pretty clean and useful.
Besides filtering co-variant outliers, the use case there was to filter by z-range when building 3D slices as part of a raster3D import, when the import data value for the raster is not the "z" column; see the r3.in.xyz.py module for an example of how it is used. (unrelated, but I'd also note that the parallelization method for z-level slice import in r3.in.xyz works out to be surprisingly efficient)
regards
Hamish <hamish.webmail at gmail.com>
