[GRASS-dev] GRASS created geotiff do not properly load into PostGIS (raster2pgsql)
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Mon May 19 00:27:47 PDT 2014
Hi again,
Just to leave a note in case others encounter the same problem and read this thread:
1)      It seems the problem occurs only with rasters in double or floating point precision (a test with integer (Int16) rasters worked fine). However, other integer types may cause problems too: see http://trac.osgeo.org/gdal/browser/trunk/gdal/gcore/gdalrasterband.cpp, where the CPLIsNan function handles NaN explicitly for some data types (see also: http://osgeo-org.1560.x6.nabble.com/gdal-dev-GDALSetRasterNoDataValue-and-NaN-td4996633.html).
2)      GDAL handles NaN without problems, at least on Linux and Windows (I have no Mac for testing).
In any case, I reopened a relevant ticket on this issue which I found in PostGIS trac: http://trac.osgeo.org/postgis/ticket/828
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140519/601dfc68/attachment.html>
