[GRASS-dev] [GRASS GIS] #2120: wxgui: encoding errors
GRASS GIS trac at osgeo.org
Mon May 19 07:56:26 PDT 2014
 Reporter:  mlennert         |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  major            |   Milestone:  6.4.4
Component:  wxGUI            |     Version:  svn-releasebranch64
 Keywords:  locale encoding  |    Platform:  All
      Cpu:  All              |
Changes (by hcho):
  * priority:  normal => major
  * platform:  Unspecified => All
  * cpu:  Unspecified => All
Comment:
 There seems to be a real fix other than changing the default encoding.
 Hopefully your explanation is helpful to the wxGUI devs for fixing the bug
 in the correct way.
 Meanwhile the users who are bothered by the issue, including me, can work
 around it by creating usercustomize.py.
 Also I would say this is major or even blocker?, not normal because some
 functionalities are not working at all because of this issue. It's not
 simply an annoyance.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2120#comment:11>
