[GRASS-dev] G7: r.neighbors changes data type from CELL to DCELL
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Mon May 19 10:53:16 PDT 2014
>r60346 implements the following logic:
>For any aggregate, there are 2 factors affecting the output type:
>1. Whether the input map is integer or floating-point.
>2. Whether the weighted or unweighted version of the aggregate is used.
Out of curiosity, could this logic also be applied to r.resamp.stats?
Or did this module already receive a similar solution?
Cheers
Stefan
