[GRASS-dev] [GRASS GIS] #2300: v.out.ogr: spatialite support not working
GRASS GIS trac at osgeo.org
Mon May 19 18:31:11 PDT 2014
 Reporter:  hamish                 |       Owner:  grass-dev@…
     Type:  defect                 |      Status:  new
 Priority:  critical               |   Milestone:  6.4.4
Component:  Vector                 |     Version:  svn-trunk
 Keywords:  v.out.ogr, spatialite  |    Platform:  Linux
      Cpu:  x86-64                 |
 Hi, as noted on the grass-users ML,
  http://lists.osgeo.org/pipermail/grass-user/2014-May/070328.html
 I'm not able to get Spatialite export working from v.out.ogr. Seen on both
 GRASS 6.x and latest trunk for debian/wheezy.
 Loading the mapset into the qgis grass toolbox on the same machine and
 saving from there works, so I think the system libraries are all ok (gdal
 1.9.0).
 for my test I'm trying the usgsgages vector map from the North Carolina
 dataset. I've tried roadsmajor type=line and census_wake2000 type=area and
 they give the same trouble.
 v.out.ogr in=usgsgages dsn=usgsgages.sqlite \
    format=SQLite type=point dsco='SPATIALITE=yes'
 the error, reported for each point is:
 ERROR 1: sqlite3_step() failed:
   usgsgages.GEOMETRY violates Geometry constraint [geom-type or SRID not
 allowed] (19)
 In trunk it seems to be happening on line 128 of v.in.ogr's export_lines.c
 (~788 in main.c for devbr6):
   OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
 api ref:
 http://www.gdal.org/ogr/ogr__api_8h.html#a301d319111285a47fe6cda6e079214f8
 MarkusN pulled up some hints from the gdal ML:
  http://lists.osgeo.org/pipermail/gdal-dev/2013-May/036148.html [[BR]]
  http://lists.osgeo.org/pipermail/gdal-dev/2013-May/036152.html
 where Even wrote:
 > The driver takes responsibility of assigning the SRID automatically from
 > the layer SRS. So the error is likely due to an attempt of inserting a
 > geometry whose type doesn't match the layer geometry type. Spatialite
 > is really strict on that: POLYGON != MULTIPOLYGON, and (perhaps I'm not
 > sure) 2D != 2.5D
 In the gdal-dev thread the solution was to pick the correct one
 of OGR_G_SetPoint() vs. OGR_G_SetPoint_2D(), maybe that helps here?
 the code seems suitably pointy, even if it is embedded in the "lines" part
 of the code, but I wonder if 2D vs 3D definition is causing trouble?
 Converting usgsgages to a 3D points map didn't help.
     else if ((type == GV_POINT) ||
              ((type == GV_CENTROID) && (otype & GV_CENTROID))) {
         Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
         OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
                        Points->z[0]);
 from the partially created sqlite file created by v.out.ogr here's the
 creation log:
 $ echo "SELECT * from spatialite_history;" | sqlite3 usgsgages4.sqlite
 1|spatial_ref_sys||table successfully created|2014-05-19
 23:14:31|1|3.7.13|3.0.0-beta
 2|geometry_columns||table successfully created|2014-05-19
 23:14:31|2|3.7.13|3.0.0-beta
 3|spatial_ref_sys||table successfully populated|2014-05-19
 23:14:32|3|3.7.13|3.0.0-beta
 4|usgsgages|GEOMETRY|Geometry [POINT,XY,SRID=40004] successfully
 created|2014-05-19 23:14:33|3.7.13|3.0.0-beta
 5|usgsgages|GEOMETRY|R*Tree Spatial Index successfully created|2014-05-19
 23:14:34|3.7.13|3.0.0-beta
 One thing I notice is that SRID 40004 is a custom one added at the
 end of the spatial_ref_sys table, after four other custom ones from
 Italy. I'm not sure if that is relevant or not.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2300>
