[GRASS-dev] [GRASS GIS] #2298: r.stream.order hack= generates order 1 single pixels
GRASS GIS trac at osgeo.org
Tue May 20 03:24:34 PDT 2014
 Reporter:  hcho            |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  7.1.0
Component:  Raster          |     Version:  svn-trunk
 Keywords:  r.stream.order  |    Platform:  Linux
      Cpu:  x86-64          |
Comment(by hellik):
 Replying to [comment:4 hcho]:
 > Unfortunately, accumulation map didn't help. I got the same result.
 Maybe, flow direction map is still used for calculating orders? and
 accumulation map is optional for doing something else...?
 see:
 -a
     Use flow accumulation to trace horton and hack models
 did you use this flag when accumulation map is used as input?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2298#comment:6>
