[GRASS-dev] [GRASS GIS] #2295: import of large shapefile in GRASS-db crashes 6.4.3 + 7.0 beta2
trac at osgeo.org
Wed May 21 19:49:59 PDT 2014
Reporter: janhuizinga | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.4
Component: LibVector | Version: 6.4.3
Keywords: v.in.ogr | Platform: MSWindows 7
Cpu: x86-64 |
Changes (by neteler):
* keywords: => v.in.ogr
* component: Default => LibVector
Old description:
> OS: Windows 7
> GRASS versions: 6.4 + 7.0 beta2
> I'm trying to import a shapefile containing 9,354,125 point of type 2.5D
> in a GRASS-db. Size of this shapefile: 328MB for shp-file + 301MB for
> dbf-file.
> If I try to import it WITH creating an attribute table it only loads half
> of the points and then exits with an error message (message attached
> below). Size of coor-file in GRASS is then 173MB.
> If I try to import the shapefile WITHOUT creating an attribute table it
> fully converts the points, but reports an memory error during
> "Registering primitives ..." Size of coor-file in GRASS is then 337MB
> (message attached below)
> Error messages in command console below:
> error 1:
> (Fri May 16 13:20:20 2014)
> v.in.ogr dsn=D:\Users\HKV2\PR2820_Mego\JanH\Gebouwen3\adreslocatie.shp
> layer=adreslocatie output=adreslocatie
> Check if OGR layer <adreslocatie> contains polygons...
> Importing 9354125 features (OGR layer <adreslocatie>)...
> WARNING: System not initialized. Programmer forgot to call G_gisinit().
> dbmi: Protocol error
> ERROR: Cannot insert new row: insert into adreslocatie values ( 4802001,
> '0363200000223289', '1011LH', 3, 300 )
> (Fri May 16 13:28:58 2014) Command finished (8 min 38 sec)
> error 2:
> (Fri May 16 14:58:19 2014)
> layer=adreslocatie output=adreslocatie --overwrite -t
> WARNING: Vector map <adreslocatie> already exists and will be overwritten
> WARNING: Table <adreslocatie> linked to vector map <adreslocatie> does
> not exist
> Building topology for vector map <adreslocatie at calc>...
> Registering primitives...
> Current region rows: 516, cols: 790
> ERROR: G_realloc: unable to allocate 81480000 bytes of memory at
> cindex.c:113
> (Fri May 16 15:08:04 2014) Command finished (9 min 44 sec)
New description:
OS: Windows 7
in a GRASS-db. Size of this shapefile: 328MB for shp-file + 301MB for dbf-
file.
fully converts the points, but reports an memory error during "Registering
primitives ..." Size of coor-file in GRASS is then 337MB (message attached
below)
error 1:
error 2:
WARNING: Table <adreslocatie> linked to vector map <adreslocatie> does not
exist
cindex.c:113
Comment:
Did you use GRASS 6 in both cases or does GRASS 7 generate the same
errors?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2295#comment:2>
