[GRASS-dev] [GRASS GIS] #2304: Problems with add category to all features workflow
trac at osgeo.org
Thu May 22 01:32:18 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: unspecified
Keywords: v.edit, v.category | Platform: Unspecified
Cpu: Unspecified |
Comment(by mlennert):
This sound more like a usage (and partly documentation) problem to me.
The v.edit man page clearly says:
catadd: Set new categories to selected vector features for defined layer
i.e. you have to select the features you want to add cats to using any of
the selection options v.edit offers (id, bbox, coords, polygon, ...). If
you don't select anything, no feature will be touched. For example, you
can just use v.info -g to get the bbox. Obviously, your -r trick does
work, but v.edit works as expected.
v.category option=add only adds category values to features which do not
have category values in the chosen layer. The man page does not seem to
mention this, so this should probably be added using something like this:
Index: main.c
--- main.c (révision 60228)
+++ main.c (copie de travail)
@@ -112,7 +112,7 @@
"report;%s;"
"print;%s;"
"layers;%s",
- _("add a new category"),
+ _("add a new category to features without category"),
_("delete category (cat=-1 to delete all categories of
given layer)"),
_("change layer number (e.g. layer=3,1 changes layer 3 to
layer 1)"),
_("add the value specified by cat option to the current
category value"),
Except for this small documentation issue, I would suggest closing this
bug as invalid.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2304#comment:2>
