[GRASS-dev] [GRASS-SVN] r60414 - in grass/trunk: include/defs lib/gis misc/m.measure raster/r.surf.area vector/v.to.db
Huidae Cho
grass4u at gmail.com
Thu May 22 08:15:26 PDT 2014
FYI, I renamed G_units_to_meters_factor(_sq) to G_meters_to_units_factor(_sq)
because this function converts meters to units by multiplication, not the
other way around.
Huidae
On Thu, May 22, 2014 at 11:00 AM, <svn_grass at osgeo.org> wrote:
> Author: hcho
> Date: 2014-05-22 08:00:16 -0700 (Thu, 22 May 2014)
> New Revision: 60414
> Modified:
> grass/trunk/include/defs/gis.h
> grass/trunk/lib/gis/units.c
> grass/trunk/misc/m.measure/main.c
> grass/trunk/raster/r.surf.area/area.c
> grass/trunk/vector/v.to.db/units.c
> Log:
> libgis, r.surf.area, v.to.db, m.measure: Renamed G_units_to_meters_factor*
> to G_meters_to_units_factor*
> Modified: grass/trunk/include/defs/gis.h
> --- grass/trunk/include/defs/gis.h 2014-05-22 14:42:19 UTC (rev 60413)
> +++ grass/trunk/include/defs/gis.h 2014-05-22 15:00:16 UTC (rev 60414)
> @@ -666,8 +666,8 @@
> void G_trim_decimal(char *);
> /* units.c */
> -double G_units_to_meters_factor(int);
> -double G_units_to_meters_factor_sq(int);
> +double G_meters_to_units_factor(int);
> +double G_meters_to_units_factor_sq(int);
> const char *G_get_units_name(int, int, int);
> int G_units(const char *);
> int G_is_units_type_spatial(int);
> Modified: grass/trunk/lib/gis/units.c
> --- grass/trunk/lib/gis/units.c 2014-05-22 14:42:19 UTC (rev 60413)
> +++ grass/trunk/lib/gis/units.c 2014-05-22 15:00:16 UTC (rev 60414)
> @@ -19,7 +19,7 @@
> #include <grass/glocale.h>
> - \brief Units conversion to meters
> + \brief Units conversion from meters to units
> Units codes (gis.h):
> - U_METERS
> @@ -27,14 +27,13 @@
> - U_MILES
> - U_FEET
> - Returns a factor which converts the grid unit to meters (by
> - multiplication).
> + Returns a factor which converts meters to units (by multiplication).
> \param units units code
> \return factor
> -double G_units_to_meters_factor(int units)
> +double G_meters_to_units_factor(int units)
> switch (units) {
> case U_METERS:
> @@ -62,7 +61,7 @@
> - \brief Units conversion to square meters
> + \brief Units conversion from square meters to square units
> - U_METERS
> @@ -72,14 +71,14 @@
> - U_MILES
> - U_FEET
> - Returns a factor which converts the grid unit to square meters (by
> + Returns a factor which converts square meters to square units (by
> multiplication).
> \return factor
> -double G_units_to_meters_factor_sq(int units)
> +double G_meters_to_units_factor_sq(int units)
> switch (units) {
> case U_METERS:
> Modified: grass/trunk/misc/m.measure/main.c
> --- grass/trunk/misc/m.measure/main.c 2014-05-22 14:42:19 UTC (rev 60413)
> +++ grass/trunk/misc/m.measure/main.c 2014-05-22 15:00:16 UTC (rev 60414)
> @@ -82,8 +82,8 @@
> units_name = G_get_units_name(G_units(units->answer), 1, 0);
> sq_units_name = G_get_units_name(G_units(units->answer), 1, 1);
> - f = G_units_to_meters_factor(G_units(units->answer));
> - sq_f = G_units_to_meters_factor_sq(G_units(units->answer));
> + f = G_meters_to_units_factor(G_units(units->answer));
> + sq_f = G_meters_to_units_factor_sq(G_units(units->answer));
> G_debug(1, "using '%s (%f) %s (%f)'",
> units_name, f, sq_units_name, sq_f);
> Modified: grass/trunk/raster/r.surf.area/area.c
> --- grass/trunk/raster/r.surf.area/area.c 2014-05-22 14:42:19 UTC
> (rev 60413)
> +++ grass/trunk/raster/r.surf.area/area.c 2014-05-22 15:00:16 UTC
> (rev 60414)
> @@ -120,5 +120,5 @@
> if (units == U_UNDEFINED)
> return value;
> - return value * G_units_to_meters_factor_sq(units);
> + return value * G_meters_to_units_factor_sq(units);
> Modified: grass/trunk/vector/v.to.db/units.c
> --- grass/trunk/vector/v.to.db/units.c 2014-05-22 14:42:19 UTC (rev 60413)
> +++ grass/trunk/vector/v.to.db/units.c 2014-05-22 15:00:16 UTC (rev 60414)
> @@ -7,8 +7,8 @@
> double f, sq_f;
> rad = 0;
> - f = G_units_to_meters_factor(options.units);
> - sq_f = G_units_to_meters_factor_sq(options.units);
> + f = G_meters_to_units_factor(options.units);
> + sq_f = G_meters_to_units_factor_sq(options.units);
> if (options.units == U_RADIANS)
> rad = 1;
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-commit
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140522/712e1f8b/attachment.html>
