[GRASS-dev] undefined reference to gdal version 1.8
Rashad M
mohammedrashadkm at gmail.com
Thu May 22 15:18:01 PDT 2014
Hi Vaclav,
Thanks for reply. Re-installing Ubuntu cannot be done for my case. There
were two gdal version /usr/
and /usr/local
For the moment removing gdal from local
rm -f /usr/local/libgdal* rm -f /usr/local/bin/gdal*
and install grass and then I did just sudo make install in gdal. This
worked but still ugly solution.
On Thu, May 22, 2014 at 11:37 PM, Vaclav Petras <wenzeslaus at gmail.com>wrote:
> On Thu, May 22, 2014 at 1:35 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>> /packages/grass70-7.0/dist.x86_64-pc-linux-gnu/lib/
>> libgrass_vector.7.0.0svn.so: undefined reference to
>> `OGRGeometryTypeToName at GDAL_1.8'
> I just had that with trunk but you will not like my solution. I
> reinstalled Ubuntu. My guess is that it was caused by combined gdal
> installations. The machine had Ubuntu 14.04 (gdal 1.10) but installed from
> 13.10 (gdal 1.9) and it had also development version of gdal (gdal 1.12) in
> /opt. I don't know from where 1.8 came from.
> Vaclav
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140523/7cbc5a0c/attachment.html>
