[GRASS-dev] [GRASS GIS] #2304: Problems with add category to all features workflow
trac at osgeo.org
Fri May 23 07:53:20 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: unspecified
Keywords: v.edit, v.category | Platform: Unspecified
Cpu: Unspecified |
Comment(by wenzeslaus):
Since it was unclear to me what are the actual problems and how
complicated they are, I was not able to fill separate tickets. I'm for
closing this ticket as soon as every issue listed here is individually
addressed, e.g. by reporting new ticket or by declaring it as not an
issue.
Summary update follows.
Reported separately:
* it is not clear how to select all features in `v.edit`
* there is the `-r` trick but it is not clear if it it supported
* it is possible to get bbox and pass it (comment:2), this seems
inconvenient to me
* perhaps `-a` (Select all) flag to explicitly select all would be good
* feature request #2309
Resolved:
* `v.edit` builds topology when there is nothing to edit
* seems to be fixed by recent r60392
* `v.edit` breaks the topology/spatial index when the selection of
features was empty, ends with assert sometimes
* whatever it was, it is hidden/disabled by r60392
* `v.category` does nothing for `option=add`; using `option=sum under`
the same conditions gives a result if there is something else to add, it
is not in the example in manual
* the issue with `option=add` is just unclear documentation
* fixed by r60432 and others
Unresolved:
* some parameters/options in `v.edit` have guisection Selection but they
can be used also as an input
* there is a space after map name in `v.what` output
* `v.category` has a parameter/option option while `v.edit` has a
parameter tool
* `v.category` builds topology when there was no change
* `v.category` does nothing for `option=step`; using `option=sum` under
* v.category says 0 features modified. when it finished report or print
but it seems redundant I wouldn't expect something else when using report
or print and not providing output
* in GUI query tool, you will see that it shows only one layer and one
category
* now I see that layers are there but they are represented as separate
maps which is not what I would expect since (layers are "inside" the map);
I missed that before because I was querying more than one map and I
considered the other (folded) row as one of the other maps
* this needs separate ticket
* underlying `vector_what(map="...", coord=...)` and `v.what` works but
maybe the output is hard to work with (applies especially to `vector_what`
function)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2304#comment:5>
