[GRASS-dev] libLAS on Ubuntu 14.04
Vaclav Petras
wenzeslaus at gmail.com
Fri May 23 13:04:34 PDT 2014
On Fri, May 23, 2014 at 3:35 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
> Hi Vaclav,
> If it helps: http://trac.osgeo.org/grass/ticket/2065
> Thanks, I tried to unify the variables (r57541 and the patch from #2065):
CFLAGS="$CFLAGS $LIBLAS_CFLAGS $LIBLAS_INC"
CPPFLAGS="$CPPFLAGS $LIBLAS_CPPFLAGS $LIBLAS_INC"
but it did not help. I see that the ticket is closed and it puzzles me that
it is not enough for me.
> On Fri, May 23, 2014 at 9:25 PM, Vaclav Petras <wenzeslaus at gmail.com>wrote:
>> On Fri, May 23, 2014 at 2:53 PM, Glynn Clements <glynn at gclements.plus.com
>> > wrote:
>>> Vaclav Petras wrote:
>>> > So the test failed with segmentation fault
>>> Possibly due to linking with gcc rather than g++. But that doesn't
>>> matter, as configure tests don't normally try to execute the program
>>> (that doesn't work if you're cross-compiling); they only care whether
>>> linking succeeds.
>> I have to remember this gcc vs g++ possible issue and that ./cofigure
>> does not execute. However, it did not helped me now. My sample program
>> still segfaults when compiled with g++.
I've tried also cxxflags and a file with cpp extension:
g++ liblastest.cpp -o liblastest -ggdb $(liblas-config --libs)
$(liblas-config --includes) $(liblas-config --cxxflags)
but it still segfaults (with and without -ggdb). Should I report this
somewhere (Launchpad, libLAS)?
> but it would actually fail
>>> > during compilation if I would use `liblas-config --libs` because the
>>> boost
>>> > libraries are `libboost_program_options.so.1.54.0` on my computer while
>>> > `liblas-config --libs` says just `libboost_program_options.so` (same
>>> for
>>> > thread library).
>>> You may need to install a -devel package, e.g. boost-devel or
>>> whatever.
>>> Typically, the unversioned symlink is in the -devel package, as it's
>>> only needed for compiling programs which use the library; running them
>>> will use either the library itself or a symlink which includes at
>>> least the major version number.
>> I installed libboost-thread-dev and libboost-program-options-dev and
>> compilation works with $(liblas-config --libs) $(liblas-config --includes).
>> So, it should work in ./configure but the result is still "libLAS support:
>> no".
>>> Glynn Clements <glynn at gclements.plus.com>
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
> Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140523/0e96b304/attachment.html>
