[GRASS-dev] libLAS on Ubuntu 14.04
Rashad M mohammedrashadkm at gmail.com
Fri May 23 14:03:10 PDT 2014
Much interesting why it ask for c++ when using C headers ?
On Fri, May 23, 2014 at 10:58 PM, Vaclav Petras <wenzeslaus at gmail.com>wrote:
> On Fri, May 23, 2014 at 4:52 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>> Hi Vaclav,
>> try linking to las_c instead of las
>> gcc liblastest.c -o liblastest -ggdb -L/usr/lib -llas_c /usr/lib/libgdal.so
>> /usr/lib/libgeotiff.so /usr/lib/x86_64-linux-gnu/libtiff.so
>> boost and las.so not required here, i think
>> Thanks but no success here.
>> On Fri, May 23, 2014 at 10:04 PM, Vaclav Petras <wenzeslaus at gmail.com>wrote:
>>> On Fri, May 23, 2014 at 3:35 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>>>> Hi Vaclav,
>>>> If it helps:  http://trac.osgeo.org/grass/ticket/2065
>>>> Thanks, I tried to unify the variables (r57541 and the patch from
>>> #2065):
>>> CFLAGS="$CFLAGS $LIBLAS_CFLAGS $LIBLAS_INC"
>>> CPPFLAGS="$CPPFLAGS $LIBLAS_CPPFLAGS $LIBLAS_INC"
>>> but it did not help. I see that the ticket is closed and it puzzles me
>>> that it is not enough for me.
>>>> On Fri, May 23, 2014 at 9:25 PM, Vaclav Petras <wenzeslaus at gmail.com>wrote:
>>>>> On Fri, May 23, 2014 at 2:53 PM, Glynn Clements <
>>>>> glynn at gclements.plus.com> wrote:
>>>>>> Vaclav Petras wrote:
>>>>>> > So the test failed with segmentation fault
>>>>>> Possibly due to linking with gcc rather than g++. But that doesn't
>>>>>> matter, as configure tests don't normally try to execute the program
>>>>>> (that doesn't work if you're cross-compiling); they only care whether
>>>>>> linking succeeds.
>>>>> I have to remember this gcc vs g++ possible issue and that ./cofigure
>>>>> does not execute. However, it did not helped me now. My sample program
>>>>> still segfaults when compiled with g++.
>>> I've tried also cxxflags and a file with cpp extension:
>>> g++ liblastest.cpp -o liblastest -ggdb $(liblas-config --libs)
>>> $(liblas-config --includes) $(liblas-config --cxxflags)
>>> but it still segfaults (with and without -ggdb). Should I report this
>>> somewhere (Launchpad, libLAS)?
>>>  > but it would actually fail
>>>>>> > during compilation if I would use `liblas-config --libs` because
>>>>>> the boost
>>>>>> > libraries are `libboost_program_options.so.1.54.0` on my computer
>>>>>> while
>>>>>> > `liblas-config --libs` says just `libboost_program_options.so`
>>>>>> (same for
>>>>>> > thread library).
>>>>>> You may need to install a -devel package, e.g. boost-devel or
>>>>>> whatever.
>>>>>> Typically, the unversioned symlink is in the -devel package, as it's
>>>>>> only needed for compiling programs which use the library; running them
>>>>>> will use either the library itself or a symlink which includes at
>>>>>> least the major version number.
>>>>> I installed libboost-thread-dev and libboost-program-options-dev and
>>>>> compilation works with $(liblas-config --libs) $(liblas-config --includes).
>>>>> So, it should work in ./configure but the result is still "libLAS support:
>>>>> no".
>>>>>> Glynn Clements <glynn at gclements.plus.com>
>>>>> _______________________________________________
>>>>> grass-dev mailing list
>>>>> grass-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>>>> Regards,
>>>>    Rashad
>> Regards,
>>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140523/0eb001b2/attachment.html>
