[GRASS-dev] [GRASS GIS] #2311: PyGRASS points read from map are always 2D although they have z coordinate
    trac at osgeo.org
    Sat May 24 18:37:34 PDT 2014
 Reporter:  annakrat     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.1.0
Component:  Python       |     Version:  svn-trunk
 Keywords:  pygrass      |    Platform:  All
      Cpu:  Unspecified  |
 When I read a 3D vector map
 from grass.pygrass.vector import VectorTopo
 vect = VectorTopo('precip_30ynormals_3d')
 vect.open()
 for point in vect[:3]:
     print point.is2D, point.z
 gives
 True None
 True None
 True None
 I am not sure how to fix it. Temporary workaround is (when I know the map
 is 3D):
     point.is2D = False
Ticket URL: <http://trac.osgeo.org/grass/ticket/2311>
