[GRASS-dev] v.edit doesn't work as described
Huidae Cho grass4u at gmail.com
Sun May 25 11:44:37 PDT 2014
Michael,
Attempt #1.
You need new lines between type, coordinates, and category lines.
echo "P 1 1
583290 4785860
1 1" | v.edit -n tool=add map=sites2 input=-
should work. The manual looks correct. I tried to put all three lines in a
single line and got the same error.
Attempt #2.
You need to export to the standard format. v.out.ascii map format=standard.
The manual also mentions format=standard.
Hope this helps.
Huidae
On Sun, May 25, 2014 at 11:54 AM, Michael Barton <Michael.Barton at asu.edu>wrote:
>  I want to add 2 new points to an existing vector map. v.edit seems to be
> a good way to do it. But I've tried to do it from standard input and from
> an ASCII file and it doesn't work. I've followed the directions in the
> manual. My guess is that the examples and docs are missing something rather
> than this being a bug. The file I want to add to is a points file with a
> linked attribute file (SQLite for GRASS 7).
>  Attempt #1:
>  GRASS 7.1.svn (Spain_utm_ed50_z30):~ > echo "P 1 1 583290 4785860 1 1" |
> WARNING: End of ASCII file reached before end of coordinates
> Building topology for vector map <sites2 at NeolSpread>...
> [nothing is built here]
>  Attempt #2
> I saved 2 points from my original vector points file (sites2) using
> v.out.ascii (file=sitesout.txt). Then I changed the coordinates to match
> those of the 2 new points I wanted to add and changed their cat numbers to
> the next 2 following the last in the existing file.
>  GRASS 7.1.svn (Spain_utm_ed50_z30):~ > v.edit -n tool=add map=sites2
> input=/Users/cmbarton/Dropbox/papers\ in\
> progress/Neolithic_spread\ 2013/Paper2/Data\ for\ experiments\
> 7-8/sitesout.txt
> WARNING: Error reading ASCII file: (unknown type) [583290|4785860|173]
>  So neither method works as described in the examples for the manual.
>  What's missing here?
>  Michael
>            ____________________
>  C. Michael Barton
>  Director, Center for Social Dynamics & Complexity
>  Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
>  Arizona State University
>  voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
>  www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140525/ecd2122f/attachment.html>
