[GRASS-dev] [gdal-dev] RFC 46 GDAL/OGR unification adopted and commited
Helmut Kudrnovsky hellik at web.de
Sun May 25 13:04:26 PDT 2014
fyi from the GDAL-ML
http://lists.osgeo.org/pipermail/gdal-dev/2014-May/039189.html
> Motion : I move to adopt RFC 46: GDAL/OGR unification
>     http://trac.osgeo.org/gdal/wiki/rfc46_gdal_ogr_unification
The motion has been adopted with support from PSC members JukkaR, FrankW,
DanielM, TamasS and myself.
The code has also been merged in trunk now. Version number upgraded to
2.0dev.
Full rebuild needed ! Let me know if issues arise.
I've also done some unification of the online documentation on gdal.org too,
by
merging the previous gdal.org/ogr/index.html into the main
gdal.org/index.html. Basically the "make docs" target in GDAL root directory
generate the whole doc. Those changes will be reflected on the server in a
few
hours. Still work to do to update the tutorials.
I've installed in http://gdal.org/1.11/ the snapshot of the 1.11
documentation, that will be mentionned in gdal.org main page, so that the
trunk documentation can evolve more easily.
Question : I see that in http://gdal.org/credits.html we still have mentions
to past sponsors, but the sponsorship program is more or less abandonned, so
I
think we could remove the Sponsorship section, and make sure that those past
sponsors are just mentionned in the "Corporate" section.
Best regards,
Even
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-RFC-46-GDAL-OGR-unification-adopted-and-commited-tp5142430.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
