[GRASS-dev] gsoc preferred source location
Martin Landa
landa.martin at gmail.com
Mon May 26 00:08:56 PDT 2014
2014-05-26 9:05 GMT+02:00 Luca Delucchi <lucadeluge at gmail.com>:
> On 23 May 2014 19:02, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> I don't think that grass-addons are appropriate. I consider grass-addons as
>> extension/addon/plugin repository, so thinks which you can install into
>> GRASS make sense there. r3.flow definitely does. I'm not so sure about
>> testing framework or metadata. sandbox make seems like more appropriate in
>> this case (no structure required or expected).
>> sandbox/gsoc
>> sandbox/gsoc/2014/
>> sandbox/gsoc/2014/metadata
> +1 for use sandbox...
agreed, Martin
