[GRASS-dev] gsoc preferred source location
Luca Delucchi lucadeluge at gmail.com
Mon May 26 00:05:40 PDT 2014
On 23 May 2014 19:02, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> I don't think that grass-addons are appropriate. I consider grass-addons as
> extension/addon/plugin repository, so thinks which you can install into
> GRASS make sense there. r3.flow definitely does. I'm not so sure about
> testing framework or metadata. sandbox make seems like more appropriate in
> this case (no structure required or expected).
> sandbox/gsoc
> sandbox/gsoc/2014/
> sandbox/gsoc/2014/metadata
+1 for use sandbox...
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
