[GRASS-dev] g.mlist: output (to ASCII file) parameter wish
Mon May 26 15:57:33 PDT 2014
Huidae Cho wrote:
> BTW, does r.series take input from stdin? In terminal, g.mlist ¦ r.series
> would be great.
It doesn't understand "file=-" as referring to stdin (although that
would be a simple change), but on Unix you can typically use e.g.
"g.mlist | r.series file=/dev/stdin".
