[GRASS-dev] problems building grass7_trunk on debian wheezy
epi
massimodisasha at gmail.com
Mon May 26 16:46:14 PDT 2014
trying to upgrade my grass7 installation i got errors for the following modules :
v.kernel, v.net.path, v.to.db, m.measure
Attached as gist the full build log for each module :
https://gist.github.com/anonymous/cc53f782312fb347ee26
for both v.to.db and m.measure the erros seems to be related to an undefined “G_units_to_meters_*”
while v.kernel, v.net.path are pointing to problems in vect.h
have you any clue ?
Thanks for help.
Massimo.
