[GRASS-dev] TGRASS broken in relbranch70: stack smashing detected: python terminated
Sören Gebbert soerengebbert at googlemail.com
Wed May 28 04:17:09 PDT 2014
Hi Markus,
i have back-ported all important bugfixes and changes from grass71
trunk to grass70 release in r60532 and r60534. Module and library
testing was successful, so i hope i did not break anything. But i did
not tested with Anna's teaching script.
I hope that fixed the issue,
best regards
Soeren
2014-05-28 7:26 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> Hi,
> TGRASS is currently broken in G7.0.svn.  Running Anna's teaching
> script (http://courses.ncsu.edu/mea592/common/Assign_GISmdmodel/a_temporal.html,
> the second part on climate) fails:
> GRASS 7.0.0svn (nc_climate_spm_2000_2012):~ > t.create
> output=precipsum type=strds temporaltype=absolute
> title="Precipitation" \
>>  description="Monthly precipitation in NC [mm]"
> ERROR: Unable to execute transaction:
> -- This SQL script generates the table in which all registered GRASS_MAP
> maps
> -- are listed in.
> -- This table will be created for each STDS.
> -- Author: Soeren Gebbert soerengebbert <at> googlemail <dot> com
> -- SPACETIME_NAME is a placeholder for specific stds name (SQL compliant):
> name_mapset
> -- GRASS_MAP is a placeholder for specific map type: raster, raster3d or
> vector
> -- This table stores the.ids of the GRASS_MAP maps registered in the
> current spacetime GRASS_MAP table
> CREATE TABLE SPACETIME_NAME_GRASS_MAP_register (
> id VARCHAR NOT NULL, -- This colum is a primary key storing the registered
> GRASS_MAP map.ids
> PRIMARY KEY (id)
> CREATE INDEX raster_map_register_3f85a9eb73d64bc2b3451204e12af4df_index ON
> raster_map_register_3f85a9eb73d64bc2b3451204e12af4df (id);INSERT INTO
> strds_base ( name ,creator ,mapset ,creation_time ,modification_time
> ,temporal_type ,id ,semantic_type ) VALUES ('precipsum' ,'neteler'
> ,'climate_1970_2012' ,'2014-05-28 02:01:56.688439' ,'2014-05-28
> 02:01:56.688537' ,'absolute' ,'precipsum at climate_1970_2012' ,'mean') ;
> INSERT INTO strds_absolute_time ( start_time ,granularity ,id ,map_time
> ,end_time ) VALUES (NULL ,NULL ,'precipsum at climate_1970_2012' ,NULL ,NULL)
> INSERT INTO strds_spatial_extent ( north ,bottom ,west ,top ,proj ,east ,id
> ,south ) VALUES (NULL ,NULL ,NULL ,NULL ,'XY' ,NULL
> ,'precipsum at climate_1970_2012' ,NULL) ;
> INSERT INTO strds_metadata ( max_min ,description ,ewres_min ,title
> ,min_max ,nsres_min ,nsres_max ,number_of_maps ,raster_register ,command
> ,min_min ,ewres_max ,id ,max_max ,aggregation_type ) VALUES (NULL ,'Monthly
> precipitation in NC [mm]' ,NULL ,'Precipitation' ,NULL ,NULL ,NULL ,NULL
> ,'raster_map_register_3f85a9eb73d64bc2b3451204e12af4df' ,'# 2014-05-28
> 02:01:56
> t.create output="precipsum" type="strds"
> temporaltype="absolute" title="Precipitation"
> ' ,NULL ,NULL ,'precipsum at climate_1970_2012' ,NULL ,NULL) ;
> *** stack smashing detected ***: python terminated
> Traceback (most recent call last):
>   File "/home/neteler/software/grass70/dist.x86_64-unknown-linux-gnu/scripts/t.create",
> line 83, in <module>
>     main()
> line 79, in main
>     semantic, None, grass.overwrite())
>   File "/home/neteler/software/grass70/dist.x86_64-unknown-linux-gnu/etc/python/grass/temporal/open_stds.py",
> line 169, in open_new_space_time_dataset
>     sp.insert(dbif)
>   File "/home/neteler/software/grass70/dist.x86_64-unknown-linux-gnu/etc/python/grass/temporal/abstract_space_time_dataset.py",
> line 366, in insert
>     dbif.execute_transaction(statement)
>   File "/home/neteler/software/grass70/dist.x86_64-unknown-linux-gnu/etc/python/grass/temporal/core.py",
> line 955, in execute_transaction
>     self.cursor.executescript(statement)
> sqlite3.OperationalError: table SPACETIME_NAME_GRASS_MAP_register already exists
> GRASS 7.0.0svn (nc_climate_spm_2000_2012):~ > db.tables -p
> No tables found
> It works in trunk. The reason is likely a series of missing backports.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
