[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
trac at osgeo.org
Thu May 29 17:57:43 PDT 2014
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:3 hcho]:
> Fixed the usage and displays a warning when | is used. (r60569)
> annakrat: Is the | issue on Windows only with python scripts and not
with binary modules? What exactly is the problem?
Here is the problem a user had with running r.out.xyz:
http://lists.osgeo.org/pipermail/grass-user/2013-October/069019.html
I remember having these problems with pipe as separator when calling a
module from python script on Windows. It seemed that parsing of the
command failed and it tried to evaluate whatever was after pipe as another
command. So I think, reverting might break it again but we can see
tomorrow if this issue is still there.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:6>
