[GRASS-dev] G7: t.* consistency changes for parameters and flags
Markus Neteler neteler at osgeo.org
Fri May 30 06:44:30 PDT 2014
I have taken liberty to streamline to some extent the parameter and
flag of the temporal t.+ modules for consistency (trunk r60608; relbr
r60609; more changes may be needed). The changes include
- use macros where possible (some new may yet be defined in the parser);
- standard field separator for text output;
- make messages identical as needed (potentially less confusion, less
work for translation);
- split long messages into label/description to avoid overly large GUI windows.
The following issues I came across:
1) Suboptimal flag name (-h versus --h) [several t.* modules]:
currently:
  -h   Print the column names as first row
 --h   Print usage summary
IMHO better invert this to -c behaviour as in v.db.select:
  -c   Do not include column names in output
unless there is a strong need to NOT put the column names by default
(which I think would be helpful for the user).
2) What does the -s flag do [several t.* modules]:
#% description: Activate spatial topology
perhaps change to
#% description: Check spatial topology
3) Wish:
 The t.list* modules should have a new "output=" parameter like that
recently added to g.mlist. This will help e.g Windows users who cannot
easily use backticks.
Markus
