[GRASS-dev] libLAS on Ubuntu 14.04
Yann Chemin
ychemin at gmail.com
Sat May 31 06:23:02 PDT 2014
More from config.log (thx MarkusM)
configure:6198: checking whether to use libLAS
configure:6215: checking for liblas-config
configure:6272: gcc -o conftest -g -O2 -g -O2 -fstack-protector
--param=ssp-buffer-size=4 -Wformat -Werror=format-security
-D_FORTIFY_SOURCE=2 -I/usr/include -I/usr/include/gdal
-I/usr/include/geotiff -I/usr/include/x86_64-linux-gnu
-Wl,--export-dynamic conftest.c -L/usr/lib -llas -llas_c
-L/usr/lib/x86_64-linux-gnu
/usr/lib/x86_64-linux-gnu/libboost_program_options.so
/usr/lib/x86_64-linux-gnu/libboost_thread.so /usr/lib/libgdal.so
/usr/lib/libgeotiff.so /usr/lib/x86_64-linux-gnu/libtiff.so 1>&5
configure:6266:32: fatal error: liblas/capi/liblas.h: No such file or directory
#include <liblas/capi/liblas.h>
compilation terminated.
configure: failed program was:
#line 6265 "configure"
#include "confdefs.h"
int main() {
LASReader_Create("foo");
; return 0; }
configure:6287: gcc -o conftest -g -O2 -g -O2 -fstack-protector
configure:6281:32: fatal error: liblas/capi/liblas.h: No such file or directory
#line 6280 "configure"
int main() {
; return 0; }
On 31/05/2014, Yann Chemin <ychemin at gmail.com> wrote:
> Hi,
> I have libboost-thread-dev, libboost-program-options-dev, and
> libboost-all-dev installed
> in configure options: --with-liblas-config=/usr/bin/liblas-config
> --with-liblas=yes
> still:
> checking whether to use libLAS... yes
> checking for liblas-config... /usr/bin/liblas-config
> configure: error: *** Unable to locate libLAS library.
> Full config script:
> CFLAGS="-g -Wall"
> ./configure --with-cxx --with-wxwidgets --with-freetype=yes
> --with-postgres=no --with-sqlite=yes --without-tcltk
> --enable-largefile=yes --with-freetype-includes=/usr/include/freetype2
> --with-opengl-libs=/usr/include/GL --with-readline --with-python=yes
> --with-lapack --with-gdal=/usr/bin/gdal-config
> --with-proj-share=/usr/share/proj --with-pthread
> --with-liblas-config=/usr/bin/liblas-config --with-liblas=yes
> --with-blas
> On 30/05/2014, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> On Thu, May 29, 2014 at 1:09 PM, Javier Martínez-López <
>> javi.martinez.lopez at gmail.com> wrote:
>>> Hi,
>>> I had the same problem with the latest grass 71 svn version (from
>>> today) under ubuntu 14.04 and I certainly solved it installing
>>> libboost-all-dev and the config option: --with-liblas=yes
>> Thank you. This was very helpful. The problem was that I included only
>> in my ./configure call. I thought that this is enough. When I added
>> --with-liblas=yes
>> it started to work. After ./configure ... && make, I have r.in.lidar and
>> v.in.lidar.
>> I still have just libboost-thread-dev and libboost-program-options-dev,
>> the
>> libboost-all-dev package is not necessary, although it is the simplest
>> option.
>> I don't understand the think with --with-liblas=yes, I really though I
>> read
>> here that it is not necessary (once you have --with-liblas-config) and
>> Yann
>> was saying that different combinations of --with-liblas* does not work
>> for
>> him.
>> There is still the problem with different content of CFLAGS and CPPFLAGS
>> variables (r57541 and the patch from #2065) in ./configure and also I'm
>> not
>> able to run the test program from ./configure myself. I don't know how
>> this
>> is important.
>> Thanks all for help. I'll try this also on other computers with Ubuntu
>> 14.04 and I'll let you know if it will not work.
>> Vaclav
>> On Thu, May 22, 2014 at 3:25 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>>> I was trying to compile GRASS with libLAS but ./configure says no.
>>> I used:
>>> and I have all liblas packages from standard Ubuntu 14.04 repository
>> (libLAS version is 1.7.0 which is the current stable release).
>> On Thu, May 22, 2014 at 8:47 PM, Yann Chemin <ychemin at gmail.com> wrote:
>>> I can confirm the issue,
>>> also by trying these configure options it is not helping:
>>> --with-liblas --with-liblas-config
>>> --with-liblas --with-liblas-config=/usr/bin/liblas-config
>>> --with-liblas=yes --with-liblas-config
>>> --with-liblas=yes --with-liblas-config=/usr/bin/liblas-config
>>> Also two targets are found, both valid (v1.7.0) and identical:
>>> whereis liblas-config
>>> liblas-config: /usr/bin/liblas-config /usr/bin/X11/liblas-config
>>> /usr/share/man/man1/liblas-config.1.gz
>>> $ ls -aslh /usr/bin/X11/liblas-config
>>> 4.0K -rwxr-xr-x 1 root root 2.5K Feb 26 14:43 /usr/bin/X11/liblas-config
>>> $ ls -aslh /usr/bin/liblas-config
>>> 4.0K -rwxr-xr-x 1 root root 2.5K Feb 26 14:43 /usr/bin/liblas-config
