[GRASS-dev] grass7 - python script - moving window: how to simplify/accelerate r.mapcalc?
Glynn Clements
glynn at gclements.plus.com
Sat May 31 17:52:41 PDT 2014
Helmut Kudrnovsky wrote:
> to answer my own question, new lines are not recognized correctly in the
> expression,
I should have read your follow-up before sending my reply.
But, for future reference, can you test the other two options (using
CR+LF, and using write_command())?
