[GRASS-dev] GRASS on Mac require Postscript names
Yann
ychemin at gmail.com
Sat Nov 1 04:13:11 PDT 2014
One last info, the startup warning:
MacBook:~ yann$ /Users/yann/Desktop/Grass7.1.command ; exit;
Cleaning up temporary files...
Starting GRASS GIS...
2014-11-01 16:42:08.918 Python[1706:d0b] CoreText performance note: Client called CTFontCreateWithName() using name "Lucida Grande" and got font with PostScript name "LucidaGrande". For best performance, only use PostScript names when calling this API.
2014-11-01 16:42:08.919 Python[1706:d0b] CoreText performance note: Set a breakpoint on CTFontLogSuboptimalRequest to debug.
Received EXIT message from GUI.
GRASS is not started. Bye.
logout
On Nov 1, 2014, at 16:35, Yann <ychemin at gmail.com> wrote:
> An addition to the message,
> It gives the same message each time I click the GIS Manager GUI, and slows it down.
> On Nov 1, 2014, at 16:19, Yann <ychemin at gmail.com> wrote:
>> Hi,
>> 2014-11-01 16:16:08.264 Python[1328:d0b] CoreText performance note: Client called CTFontCreateWithName() using name ".Lucida Grande UI" and got font with PostScript name ".LucidaGrandeUI". For best performance, only use PostScript names when calling this API.
>> Had the same at the startup for "LucidaGrande" requirement instead of "Lucida Grande”
>> Yann
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141101/ab873261/attachment.html>
