[GRASS-dev] Dead code
Markus Neteler
neteler at osgeo.org
Sat Nov 1 11:07:55 PDT 2014
On Sat, Nov 1, 2014 at 4:29 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Sat, Nov 1, 2014 at 6:30 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
>> On 1 November 2014 11:15, Markus Neteler <neteler at osgeo.org> wrote:
>> > Yet open:
>> > - raster/r.in.arc and raster/r.out.arc (use r.in.gdal/r.out.gdal) - ?
>> > - raster/r.in.tiff and raster/r.out.tiff (use r.in.gdal/r.out.gdal) - ?
> I think I used r.out.tiff at some point for some reason. Perhaps move to
> addons is a conservative solution. (Also allows people to transfer easily,
> i.e. install older module if they are using it, this is what I did with
> r.los, but some note in documentation should be included.)
ok, so I'll move them to Addons.
>> > - raster/r.le (sufficiently superseded by r.li?) - ?
> If they somehow work, they could be moved to addons
... they are functional, so Addons will be their new "home".
While we are at it: r.in.png and r.out.png as well... ok?
Markus
