[GRASS-dev] [GRASS GIS] #2053: r.recode: 0.0 or 1.0 as limits do not seem to be taken into account
Paulo van Breugel
p.vanbreugel at gmail.com
Sun Nov 2 23:53:05 PST 2014
> Reporter: nikosa | Owner:
> grass-dev@…
> Type: defect | Status: new
> Priority: major | Milestone: 7.0.0
> Component: Raster | Version:
> unspecified
> Keywords: r.recode, DCELL, CELL, rules, needinfo | Platform:
> Unspecified
> Cpu: Unspecified |
> Comment(by annakrat):
> Replying to [comment:13 glynn]:
> > Replying to [comment:12 annakrat]:
> > > I attached the diff for this, I decided for floor(x+0.5) logic (but we
> could use just floor if someone is against this). I would rather get some
> approval from other developers for this.
> > The advantage of floor() is that it will produce identical results to
> the existing implementation for positive values.
> > The main disadvantage of floor() is that minuscule rounding errors can
> result in the wrong value, e.g. (CELL)floor(1.9999999) is 1 rather than 2.
> Thanks for the summary, but I was mainly asking for opinions which one
> should we use. I prefer rounding to the nearest integer, even though it
> can give different results. Anyone has the same/different opinion?
+1 for rounding to the nearest integer
> Ticket URL: <http://trac.osgeo.org/grass/ticket/2053#comment:14>
> GRASS GIS <http://grass.osgeo.org>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141103/b0f376f6/attachment.html>
