[GRASS-dev] Fwd: New Defects reported by Coverity Scan for grass
Markus Neteler
neteler at osgeo.org
Mon Nov 3 01:13:22 PST 2014
I have submitted r62566 from today to Coverity Scan, results below.
Markus
---------- Forwarded message ----------
Date: Mon, Nov 3, 2014 at 9:57 AM
Subject: New Defects reported by Coverity Scan for grass
To: neteler at osgeo.org
Please find the latest report on new defect(s) introduced to grass
found with Coverity Scan.
5 new defect(s) introduced to grass found with Coverity Scan.
26 defect(s), reported by Coverity Scan earlier, were marked fixed in
the recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan
Showing 5 of 5 defect(s)
** CID 1207286: Unchecked return value (CHECKED_RETURN)
/imagery/i.atcorr/main.cpp: 419 in copy_colors(const char *, char *)()
** CID 1207285: Unchecked return value (CHECKED_RETURN)
/lib/ogsf/gs3.c: 592 in Gs_build_256lookup()
** CID 1207284: Unchecked return value (CHECKED_RETURN)
/lib/ogsf/gs3.c: 654 in Gs_pack_colors()
** CID 1207283: Unchecked return value (CHECKED_RETURN)
/lib/ogsf/gs3.c: 725 in Gs_pack_colors_float()
** CID 1207209: Unchecked return value (CHECKED_RETURN)
/imagery/i.pca/support.c: 19 in write_support()
________________________________________________________________________________________________________
*** CID 1207286: Unchecked return value (CHECKED_RETURN)
413
414 /* Copy the colors from map named iname to the map named oname */
415 static void copy_colors(const char *iname, char *oname)
416 {
417 struct Colors colors;
418
>>> Calling "Rast_read_colors" without checking return value (as is done elsewhere 50 out of 61 times).
419 Rast_read_colors(iname, "", &colors);
420 Rast_write_colors(oname, G_mapset(), &colors);
421 }
422
423
424 /* Define our module so that Grass can print it if the user
wants to know more. */
*** CID 1207285: Unchecked return value (CHECKED_RETURN)
586 mapset = G_find_raster2(filename, "");
587 if (!mapset) {
588 G_warning(_("Raster map <%s> not found"), filename);
589 return 0;
590 }
591
592 Rast_read_colors(filename, mapset, &colrules);
593 Rast_get_c_color_range(&min, &max, &colrules);
594
595 if (min < 0 || max > 255) {
596 G_warning(_("Color table range doesn't match data
(mincol=%d, maxcol=%d"),
597 min, max);
*** CID 1207284: Unchecked return value (CHECKED_RETURN)
648
649 r = (unsigned char *)G_malloc(cols);
650 g = (unsigned char *)G_malloc(cols);
651 b = (unsigned char *)G_malloc(cols);
652 set = (unsigned char *)G_malloc(cols);
653
654 Rast_read_colors(filename, mapset, &colrules);
655
656 cur = buff;
657
658 G_message(_("Translating colors from raster map <%s>..."),
659 G_fully_qualified_name(filename, mapset));
*** CID 1207283: Unchecked return value (CHECKED_RETURN)
719
720 r = (unsigned char *)G_malloc(cols);
721 g = (unsigned char *)G_malloc(cols);
722 b = (unsigned char *)G_malloc(cols);
723 set = (unsigned char *)G_malloc(cols);
724
725 Rast_read_colors(filename, mapset, &colrules);
726
727 fcur = fbuf;
728 icur = ibuf;
729
730 G_message(_("Translating colors from raster map <%s>..."),
*** CID 1207209: Unchecked return value (CHECKED_RETURN)
13 const char *mapset = G_mapset();
14 struct Colors colors;
15 struct FPRange range;
16 DCELL min, max;
17
18 if (inname) {
19 Rast_read_colors(inname, "", &colors);
20 }
21 else {
22 /* make grey scale color table */
23 Rast_read_fp_range(outname, mapset, &range);
24 Rast_get_fp_range_min_max(&range, &min, &max);
To view the defects in Coverity Scan visit,
http://scan.coverity.com/projects/1038?tab=overview
