[GRASS-dev] v.what: test_vwhat_layers is failing
Vaclav Petras
wenzeslaus at gmail.com
Mon Nov 3 06:18:05 PST 2014
It seems that v.what's test_vwhat_layers test file is randomly failing time
to time with "ERROR: Unable to start driver <(null)>".
ERROR: setUpClass (__main__.TestMultiLayerMap)
File "vector/v.what/testsuite/test_vwhat_layers.py", line 121, in
setUpClass
cls.runModule('db.in.ogr', dsn='./data/table1.csv', output='t1')
File "etc/python/grass/gunittest/case.py", line 953, in runModule
errors=errors)
CalledModuleError: Module run 1 db.in.ogr ended with error
Process ended with non-zero return code db.in_ogr(dsn='./data/table1.csv',
output='t1'). See the following errors:
File "scripts/db.in.ogr", line 127, in <module>
main()
File "scripts/db.in.ogr", line 76, in main
s = grass.read_command('db.tables', flags = 'p')
File "etc/python/grass/script/core.py", line 420, in read_command
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None db.tables -p ended with
error
Process ended with non-zero return code 1. See errors in the (error) output.
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-11-02-08-00/report_for_nc_spm_08_grass7_nc/vector/v.what/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-11-03-08-00/report_for_nc_spm_08_grass7_nc/vector/v.what/test_vwhat_layers/index.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141103/1aba2637/attachment.html>
