[GRASS-dev] g.parser: Note on setting bash' IFS to parse separate identities
Nikos Alexandris
nik at nikosalexandris.net
Tue Nov 4 05:11:05 PST 2014
Nikos Alexandris wrote:
>> ...individual comma separated identities for an option named "input"
>> can be parsed with the following Bash shell code:
>> IFS=,
>> for opt in $GIS_OPT_INPUT ; do
>> ... "$opt"
>> done
>> Doesn't this require to set the IFS back to what it was? Maybe note
>> it
>> too?
Glynn Clements wrote:
> Yes.
> Or even just remove the reference to bash from the 7.x documentation.
> If you're using 7.x, Python is almost mandatory, so why would you
> write bash scripts?
I recently switched to all-Python :-). Yet, incomplete notes still
remain incomplete.
By the way, in Python, is .split(',') the only way to seprate
multiple (input) identities in a list/dictionary? Shouldn't the parser,
with the option "multiple: yes" do this already for the scripter?
For example, in
#%option
#% key: msx
#% type: string
#% gisprompt: old,double,raster
#% description: Low resolution multi-spectral image(s)
#% required: yes
#% multiple: yes
#%end
it would be nice to have a new list after
newlist = options['msx']
Or would this cause trouble?
Thank you,
Nikos
