[GRASS-dev] [GRASS GIS] #2326: Command functions in grass.script.core miss a correct error reporting
trac at osgeo.org
Wed Nov 5 02:48:01 PST 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: major | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: script, exceptions | Platform: All
Cpu: Unspecified |
Comment(by neteler):
The vector network toolbox seems to lack some related update (trunk from
4th of Nov 2014). We tried to run v.net.alloc therein on roads_major:
File "/home/matteo/software/grass_trunk/dist.x86_64
-unknown-linux-gnu/gui/wxpython/lmgr/frame.py", line 788, in
OnVNet
self.GetMapDisplay().OnVNet(event)
-unknown-linux-gnu/gui/wxpython/mapdisp/frame.py", line
1420, in OnVNet
self.dialogs['vnet'] = VNETDialog(parent=self,
giface=self._giface)
-unknown-linux-gnu/gui/wxpython/vnet/dialogs.py", line 134,
in __init__
self._createInputDbMgrPage()
-unknown-linux-gnu/gui/wxpython/vnet/dialogs.py", line 448,
in _createInputDbMgrPage
self.inpDbMgrData['dbMgr'] = DbMgrBase()
-unknown-linux-gnu/gui/wxpython/dbmgr/base.py", line 669, in
__init__
self.dbMgrData['mapDBInfo'] =
VectorDBInfo(self.dbMgrData['vectName'])
-unknown-linux-gnu/gui/wxpython/dbmgr/vinfo.py", line 74, in
__init__
VectorDBInfoBase.__init__(self, map)
-unknown-linux-gnu/gui/wxpython/gui_core/gselect.py", line
723, in __init__
if not self._CheckDBConnection(): # -> self.layers
731, in _CheckDBConnection
self.layers = grass.vector_db(map = self.map, stderr =
nuldev)
-unknown-linux-gnu/etc/python/grass/script/vector.py", line
42, in vector_db
**args)
-unknown-linux-gnu/etc/python/grass/script/core.py", line
420, in read_command
returncode=returncode)
grass.exceptions
CalledModuleError
Module run None v.db.connect --q -g stderr=<open file
'/dev/null', mode 'w+' at 0x7ffac45d8f60> sep=; ended with
error
Process ended with non-zero return code 1. See errors in the
(error) output.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2326#comment:27>
