[GRASS-dev] [GRASS GIS] #2473: v.net connection operation
trac at osgeo.org
Wed Nov 5 05:27:36 PST 2014
Reporter: matmar | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.net | Platform: Linux
Cpu: Unspecified |
Hi all,
I'm not able to connect points with the nearest line segment in a line
vector using v.net.
v.net connects a line vector with the points in a point vector file. The
connection process follows the category progress so the output is not the
fittest solution for a network distance analysis as the one I need to
perform.
Following, the commands to reproduce the issue in nc_spm_08_grass7:
g.region vect=roadsmajor
v.mkgrid map=points_grid -p position=region grid=20,20
v.net input=roadsmajor points=points_grid out=roads_to_points
operation=connect threshold=5000 --o
plot:
d.mon wx0
d.vect roads_to_points
d.vect points_grid col=red display=cat
Is there a way to connect each point to the nearest original road segment?
Matteo
Ticket URL: <http://trac.osgeo.org/grass/ticket/2473>
