[GRASS-dev] [GRASS GIS] #2474: G7: vector network toolbox crash
GRASS GIS trac at osgeo.org
Wed Nov 5 13:07:26 PST 2014
 Reporter:  neteler      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-releasebranch70
 Keywords:  v.net        |    Platform:  Unspecified
      Cpu:  Unspecified  |
 (copied here from trac comment:27:ticket:2326)
 The vector network toolbox seems to lack some related update (trunk from
 4th of Nov 2014). We tried to run v.net.alloc therein on roads_major:
   File "/home/matteo/software/grass_trunk/dist.x86_64
 -unknown-linux-gnu/gui/wxpython/lmgr/frame.py", line 788, in
 OnVNet
 self.GetMapDisplay().OnVNet(event)
 -unknown-linux-gnu/gui/wxpython/mapdisp/frame.py", line
 1420, in OnVNet
 self.dialogs['vnet'] = VNETDialog(parent=self,
 giface=self._giface)
 -unknown-linux-gnu/gui/wxpython/vnet/dialogs.py", line 134,
 in __init__
 self._createInputDbMgrPage()
 -unknown-linux-gnu/gui/wxpython/vnet/dialogs.py", line 448,
 in _createInputDbMgrPage
 self.inpDbMgrData['dbMgr'] = DbMgrBase()
 -unknown-linux-gnu/gui/wxpython/dbmgr/base.py", line 669, in
 __init__
 self.dbMgrData['mapDBInfo'] =
 VectorDBInfo(self.dbMgrData['vectName'])
 -unknown-linux-gnu/gui/wxpython/dbmgr/vinfo.py", line 74, in
 __init__
 VectorDBInfoBase.__init__(self, map)
 -unknown-linux-gnu/gui/wxpython/gui_core/gselect.py", line
 723, in __init__
 if not self._CheckDBConnection(): # -> self.layers
 731, in _CheckDBConnection
 self.layers = grass.vector_db(map = self.map, stderr =
 nuldev)
 -unknown-linux-gnu/etc/python/grass/script/vector.py", line
 42, in vector_db
 **args)
 -unknown-linux-gnu/etc/python/grass/script/core.py", line
 420, in read_command
 returncode=returncode)
 grass.exceptions
 CalledModuleError
 Module run None v.db.connect --q -g stderr=<open file
 '/dev/null', mode 'w+' at 0x7ffac45d8f60> sep=; ended with
 error
 Process ended with non-zero return code 1. See errors in the
 (error) output.
 A workaround has been submitted in r62614 as of trac trac
 comment:28:ticket:2326
Ticket URL: <http://trac.osgeo.org/grass/ticket/2474>
