[GRASS-dev] [GRASS GIS] #2477: r.out.gdal installed from 64bit OSGeo4W doesn't work
GRASS GIS trac at osgeo.org
Thu Nov 6 18:51:06 PST 2014
 Reporter:  tmizu23   |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:
Component:  Raster    |     Version:  6.4.3
 Keywords:            |    Platform:  MSWindows 7
      Cpu:  x86-64    |
Comment(by tmizu23):
 Replying to [comment:1 wenzeslaus]:
 I tried that with GRASS NC sample data. And I've uploaded the error
 message(in japanese sorry). the message means that "r.out.gdal has stopped
 working. A problem caused the program to stop working correctly. Windows
 will close the program and notify you if a solution is available"
 Gdal commands works correctry on OSGeo4W 64bit. But I didn't try reading
 GRASS data with gdal directry  so gdal on OSGeo4W doesn't support GRASS
 format.
 thanks
 > Thanks for the report and for testing OSGeo4W 64bit. Please provide also
 the error message and if possible, try that with GRASS NC sample location,
 so that developers can try to reproduce it eventually.
 > If you know how, it might be actually useful to try some GDAL directly,
 to see where the issue actually is.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2477#comment:2>
