[GRASS-dev] [GRASS GIS] #2473: v.net connection operation
trac at osgeo.org
Sat Nov 8 03:56:40 PST 2014
Reporter: matmar | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.net | Platform: Linux
Cpu: Unspecified |
Comment(by matmar):
Replying to [comment:1 mlennert]:
> Replying to [ticket:2473 matmar]:
> > Hi all,
> > I'm not able to connect points with the nearest line segment in a line
vector using v.net.
> > v.net connects a line vector with the points in a point vector file.
The connection process follows the category progress so the output is not
the fittest solution for a network distance analysis as the one I need to
perform.
> > Following, the commands to reproduce the issue in nc_spm_08_grass7:
> > g.region vect=roadsmajor
> > v.mkgrid map=points_grid -p position=region grid=20,20
> > v.net input=roadsmajor points=points_grid out=roads_to_points
operation=connect threshold=5000 --o
> > plot:
> > d.mon wx0
> > d.vect roads_to_points
> > d.vect points_grid col=red display=cat
> > Is there a way to connect each point to the nearest original road
segment?
> Use the '-s' flag (Snap points to network) available in grass7.
> Moritz
Hi Moritz,
-s glues points to the nearest network segment but doesn't connect each
point to the nearest network segment (so I lose information). I attached a
drawing about what I meant, hoping it helps.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2473#comment:2>
