[GRASS-dev] [GRASS GIS] #2466: r.param.scale slow on Windows when there is no data in raster
GRASS GIS trac at osgeo.org
Mon Nov 10 07:36:39 PST 2014
  Reporter:  annakrat     |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Raster       |     Version:  unspecified
Resolution:  fixed        |    Keywords:  r.param.scale, nan
  Platform:  MSWindows 8  |         Cpu:  Unspecified
Changes (by annakrat):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:4 annakrat]:
 > Replying to [comment:3 glynn]:
 > > AFAICT, you either need to accept that nulls will propagate (i.e. if
 any cell in the window is null, the result will be null), or replace the
 least-squares fitting algorithm with something which can handle nulls.
 > I changed it so that nulls propagate (r62648). I will test on Windows if
 there will be any speed difference.
 Tested on Windows, it is running fast now. Backported in r62692. Closing
 ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2466#comment:5>
