[GRASS-dev] [GRASS GIS] #2326: Command functions in grass.script.core miss a correct error reporting
trac at osgeo.org
Tue Nov 11 10:34:14 PST 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: major | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: script, exceptions | Platform: All
Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:33 neteler]:
> While no crash occurs any more with r62705, it doesn't stop any longer
on error:
GRASS 7.1.svn (nc_spm_08_grass7):~ > r.basin map=elevation prefix=my_basin
coord=637500.0,221750.0 dir=/tmp/bla threshold=1000 --o
WARNING: 'r.width.funct' required. Please install 'r.width.funct' first
using 'g.extension r.width.funct'
ERROR: An ERROR occurred running r.basin
SECTION 1 beginning: Initiating Variables. 4 sections total.
`r.basin` is using function `error()` which is something different than
function `fatal()`. `error()` just prints the message and continues,
`fatal()` actually exits and raises. So, the behavior is correct according
to implementation and is the same before r62566 and after r62705.
* source:grass-addons/grass7/raster/r.basin/r.basin.py?rev=62705#L80
* source:grass/trunk/lib/python/script/core.py?rev=62705#L569
r62705 is doing two things. It adds a possibility to select method of
error handling and unifies the implementation (see previous comments for
discussion). Additionally it solves the issue with `g.message` which
returns non-zero return code when an error is printed:
GRASS > g.message "Hello!"
Hello!
GRASS > echo $?
0
GRASS > g.message -w "Hello!"
WARNING: Hello!
GRASS > echo $?
0
GRASS > g.message -e "Hello!"
ERROR: Hello!
GRASS > echo $?
1
I suppose that `g.message` behavior is advantageous for terminations of
shell scripts using `set -e`. This makes `g.message` special comparing to
other GRASS modules (alongside with `g.findfile`). You may find something
like this in one of the earlier patches in this ticket, I forgot about it
this time.
Note also that the changes in error handling were applied to trunk only.
The changes for addons are basically done but not committed because addons
are supposed to be compatible with release branch. Also the changes will
be done only for modules which are doing the correct error handling. The
code ignoring errors will not be changed. Introduction of raise will show
these ignored errors and will prevent further execution of the
module/script since the the error occurred.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2326#comment:34>
