[GRASS-dev] [GRASS GIS] #2326: Command functions in grass.script.core miss a correct error reporting
trac at osgeo.org
Wed Nov 12 01:21:05 PST 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: major | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: script, exceptions | Platform: All
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:34 wenzeslaus]:
> I suppose that `g.message` behavior is advantageous for terminations of
shell scripts using `set -e`. This makes `g.message` special comparing to
other GRASS modules
Not really ...
Like (almost?) any other GRASS module, g.message returns a non-zero exit
code if a fatal error was generated, and a zero exit code otherwise.
g.message calls a different function (G_verbose_message(), G_warning()
etc) depending upon the flag which was used (defaulting to G_message() if
no flag was used). If the -e flag is used, it calls G_fatal_error(), hence
the non-zero exit code.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2326#comment:39>
