[GRASS-dev] grass7 addon python script - finishes in normal and --verbose mode, but not in --quiet mode
Helmut Kudrnovsky
hellik at web.de
Thu Nov 13 12:44:11 PST 2014
tested here with:
GRASS Version: 7.1.svn
GRASS SVN Revision: 62712
Erstellungsdatum: 2014-11-12
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
running the addon script [1] in normal and --verbose mode:
v.fixed.segmentpoints vector=iselflipped at myricaria cat=1
dir=C:\tmp\grassscript distance=25000
Extract vector line for which segment points should be calculated ...
v.fixed.segmentpoints done!
(Thu Nov 13 21:36:52 2014) Befehl ausgeführt (43 Sek)
v.fixed.segmentpoints --verbose vector=iselflipped at myricaria cat=1
(Thu Nov 13 21:39:03 2014) Befehl ausgeführt (35 Sek)
it works.
but in --quiet mode it fails with:
v.fixed.segmentpoints --quiet vector=iselflipped at myricaria cat=1
File "C:\Users\myricaria\AppData\Roaming\GRASS7\addons/scr
ipts/v.fixed.segmentpoints.py", line 226, in <module>
sys.exit(main())
ipts/v.fixed.segmentpoints.py", line 100, in main
vector_line_length =
float(tmp.split('\n')[1].split('|')[1])
IndexError: list index out of range
(Thu Nov 13 21:40:08 2014) Befehl ausgeführt (2 Sek)
any idea?
thanks
[1]
http://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.fixed.segmentpoints
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/grass7-addon-python-script-finishes-in-normal-and-verbose-mode-but-not-in-quiet-mode-tp5172902.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
