[GRASS-dev] grass7 addon python script - finishes in normal and --verbose mode, but not in --quiet mode
Helmut Kudrnovsky hellik at web.de
Fri Nov 14 01:25:05 PST 2014
Anna Petrášová wrote
>> but in --quiet mode it fails with:
>> v.fixed.segmentpoints --quiet vector=iselflipped at myricaria cat=1
>> dir=C:\tmp\grassscript distance=25000
>> Traceback (most recent call last):
>>   File "C:\Users\myricaria\AppData\Roaming\GRASS7\addons/scr
>> ipts/v.fixed.segmentpoints.py", line 226, in
> <module>
>>     sys.exit(main())
>> ipts/v.fixed.segmentpoints.py", line 100, in main
>>     vector_line_length =
>> float(tmp.split('\n')[1].split('|')[1])
>> IndexError: list index out of range
>> (Thu Nov 13 21:40:08 2014) Befehl ausgeführt (2 Sek)
>> any idea?
> Could you try to print tmp with and without quiet?
http://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py#L102
102	    # Read length
103	    tmp = grass.read_command('v.to.db', map = voutline,
104	                                     type = 'line',
105	                                     layer = 1,
106	                                     qlayer = 1,
107	                                     option = 'length',
108	                                     units = 'meters',
109	                                     column = 'vlength',
110	                                     flags = 'p')
111	    vector_line_length = float(tmp.split('\n')[1].split('|')[1])
112
113	    # Print vector line length
114	    grass.message( "Vector line length in meter:" )
115	    grass.message( vector_line_length )
116	    grass.message( "----" )
it's just to get the length of the vector line for further calculations:
in normal and verbose mode:
Lese Objekte...
58858.3366368
as Moritz points out, it seems quiet mode suppresses the access to the
output of grass.read_command; his solution/workaround with GRASS_VERBOSE env
variable seems not to work here on my side.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/grass7-addon-python-script-finishes-in-normal-and-verbose-mode-but-not-in-quiet-mode-tp5172902p5172966.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
