[GRASS-dev] g.parser and "#% type: double"
Nikos Alexandris
nik at nikosalexandris.net
Sat Nov 15 07:19:49 PST 2014
Given the following
#%option
#% key: sea
#% key_desc: degrees
#% type: double
#% description: Aquisition's Sun Elevation Angle
#% options: 0.0 - 90.0
#% guisection: Metadata
#% required: yes
#%end
import grass.script as grass
def main()
sea = options['sea']
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
Isn't supposed that sea is returned as a float? Is it really
necessary to do
sea = float(options['sea'])
Grazie, Nikos
